[lammps-users] Error message while running NVT simulation for Aluminum
Steve, LAMMPS users,
I am using the script below to run a NVT (at 300K) simulation for Aluminum. I have 3 atom types which are all intended/specified to be Aluminum (via the setting of the mass) in the input(read_data) text file. However, I am getting the error as given below. I have a doubt I may not be specifying the pair coefficients correctly.
If possible, please let me know.
Sreekant
SCRIPT
sreekant,
your very first step is already having an infinite energy.
that is more likely to be the result of a bad starting configuration.
have you checked it in a visualization program for contacts?
have you tried running it with just one force field type?
cheers,
Axel,
I did have an incorrect/bad initial configuration of atoms (incorrect simulation box size specification).
While for these simulations in aluminum, I was getting a “segmentation fault” error which did not allow me to proceed at all, I had a similar incorrect specification of the box size for some simulations in silicon also. But I was able to proceed with the simulations in silicon - though I was struggling to make sense of the results. It does seem getting the correct box size for these simulations in silicon is now yielding reasonable results.
Sreekant
