[lammps-users] Error minimizing nanotube
Hey LAMMPS Users,
I have attached a file that minimizes a double-wall carbon nanotube, which is also attached. I have used it on other smaller lengths of DWNTs with no issues until I tried one of 1 um in length where I get a ‘segmentation fault–address not mapped’ error–the energies are all ‘nan’. I wanted to know is this error is inherent to my system or does someone else get the same error.
Thanks for the help.
Ebonee
in.minimize (837 Bytes)
dwnt466560-10,10-1um+b.gz (2.7 MB)
I get NANs on step 0, so I presume your initial
geometry is bad.
ebonee,
please check your simulation box dimensions.
it looks as if you have overlapping atoms in z-direction.
if i load the data file with f f f boundary conditions,
lammps complains about missing atoms (indicating
atoms outside the cell) and if i load the data file into
VMD and perform a minmax measurements, the
maximum z value is found to be 6.2 angstrom longer
than what you are using.
cheers,
Axel,
Thanks…the box size was the issue. It’s always something simple, right?
Ebonee
