We experienced a problem when running Lammps version 10 May 2010. After several time steps, lammps report the following "ERROR: Per-atom energy was not tallied on needed timestep". You will find below an input script which reproduce the problem after 39 time steps.
We do not understand why lammps report an error in that case.
Thanks for your help. Regards,
Olivier
atom_style atomic
lattice fcc 3.482
region box block 0 10 0 10 0 10
create_box 1 box
create_atoms 1 region box
mass 1 58.710
pair_style eam/alloy
pair_coeff * * NiAl02.eam.alloy Ni
neighbor 2.0 bin
neigh_modify delay 0 check yes
velocity all create 600.0 4928459
thermo 1
compute pea all pe/atom
fix 44 all nvt temp 600 600 1.0
run 30
unfix 44
dump 3 all custom 20 box-v7-3-2-600K.lammpstrj id type x y z c_pea
fix 66 all nve
run 20
unfix 66
