I am having a problem with my code on CNT\-silicon interface\. The
program is running for a while and getting terminated in between showing the
message
""ERROR: Empty brackets in input command""
what does that mean??
that you didn't pay attention to the changes in the code.
it has been written in the new features/bugs page and
commented here on the list in response to similar questions,
that the syntax for variable references has been changed.
just removing the empty brackets should do the trick.
This is the offending line:
variable temp atom c_ke[]*7739
It's running for a while, b/c the variable
doesn't get evaulated right away. Just
remove the brackets. The syntax for
variables on this issue was changed a couple months back..
