[lammps-users] expected integer parameter in input script or data file error
Hello
When I want to run test.input file in ‘lammps-3Oct10\tools\msi2lmp\test’ folder,I receive this error ‘expected integer parameter in input script or data file error’.
Can you help me.
Hello
When I want to run test.input file in 'lammps-3Oct10\tools\msi2lmp
\test' folder,I receive this error 'expected integer parameter in
input script or data file error'.
Can you help me.
the msi2lmp converter and the test inputs need to be updated
for the format requirements of the current lammps versions.
e.g., coefficients that are flagged as integer in the lammps
documentation, _have_ to be integers. floating point numbers
are no longer accepted and lead to the kind of error message
that you are seeing.
cheers,
Esi - if you or someone else makes the (small) changes necessary
to re-format these values when msi2lmp writes them out, I will
post a patch. I don't use this tool, so am not familiar with it.
