In an effort to replicate some results from a previous study I am looking at applying a pressure to a block of atoms. The way the study does it it is they apply a force to the top 4 layers of the block which corresponds to a specific pressure. I want to be sure I am approaching this problem right:
To apply the pressure should I use fix aveforce? This makes sense as it seems to be the option used when looking for something like a wall. In this case I assume I should use:
fix 1 setforce 0 0 NULL
fix 2 aveforce NULL NULL -{force} -
Assuming this is correct, when calculating the force needed for a specific pressure is it as simple as multiplying the desired pressure by the surface area (ie x and y dimensions of the box) and then doing some unit conversions? Because the force in aveforce is the average force of the group and it is only applied in the z I am thinking this, but seems too simple.
For thermostatting, the study says a thermostat/barostat was left on the weld area (no thermostat for the fixed layers) that kept pressure in the transverse direction to the atmosphere. This seems like the fix aveforce will then have to compete with this fix npt, is this true?
Thanks very much.
Liam
