Steve,
I am trying to findout how much the velocities have been modified by adding heat. Below are the few lines of the prog. In the region cold, i tried to remove some heat and i use dump command to output vel’s before and after the timestep in two different files. But both files shows the same velocities. Shouldn’t it be different.
fix 4 all nve
dump 1 cold custom 1 velbefore.txt vx vy vz
fix 7 cold heat 1 -1.0
dump 3 cold custom 1 velafter.txt vx vy vz
Ajit
