To heat a group of atoms in a geometric region, I add the two files “fix_heat_region.cpp” and “fix_heat_region.h” into LAMMPS.
The usage of “fix heat/region command” is like “fix heat command” , which can be seen in the following:
We can use it like this:
### fix heat/region commandSyntax:<br>fix ID group-ID heat/region region-ID N eflux <br><br>
- ID, group-ID are documented in fix command
- heat/region = style name of this fix command
- region-ID = ID of region to use for choosing atoms
- N = add/subtract heat every this many timesteps
- eflux = rate of heat addition or subtraction (energy/time units)
Examples:<br>fix 1 all heat/region up 1 -50.0<br>
<br> <br>
<br>Xiaoliang Zhang<br>
<br>CAS, China<br>
fix_heat_region.cpp (3.22 KB)
fix_heat_region.h (1.09 KB)
