[lammps-users] fix heat
Dear Sir,
we want to compute thermal conductivity of gold nanowire.
we want to use the  [fix](http://lammps.sandia.gov/doc/fix.html) heat command. apart of  our input file is following:
units   metal
fix 3 hifix heat 1 1.0
timestep     0.001
is that mean after 1000 steps 1eV energy transport?
if we change N in the the input :
fix 3 hifix heat 1000 1.0
what happen?
thanks
Esi,
Your first set of commands means once every 1 timestep (or every 0.001 picoseconds), you are adding 1.0 eV.
Your latter command means once every 1000 timesteps (or every 1 picosecond), you are adding 1.0 eV.
Jonathan
