[lammps-users] fix nvt command
Hello
If use the command:
“fix 1 all nvt temp 300.0 300.0 100.0”
I get an error: Illegal fix nvt command
But I use this command as it is given in the documentation.
Regards
APC
The command syntax was changed recently i think. Please see the manual in the doc directory of your installation.
The version of the code you are running is not the same as the
version of the doc page you are reading.
