Dear LAMMPS users,
I'am puzzled about the fix rigid command.
When I write an input file for a granular model with a rigid fix:
fix 0 Si rigid single
it works.
When I add the default:
fix 0 Si rigid single force * 1 1 1
it fails with the following ERROR message:
ERROR: Illegal fix rigid command.
remarks:
1.) Group Si has approx. 20000 atoms.
2.) I use periodic boundary conditions in z direction.
With kind regards,
Thomas Wagner.
The syntax is off or on, not 0 or 1.
The same ERROR with:
fix 1 clump1 rigid single force * on on on
remark: option defaults in online doc http://lammps.sandia.gov/doc/fix_rigid.html
are force * 1 1 1 and torque * 1 1 1.
Thomas.
Steve Plimpton schrieb:
The last line of the doc page was in error, with 1 instead of on.
I added this command to bench/in.lj and it works fine:
fix 2 all rigid single force * on on on
Do you have the most current LAMMPS. I think the "force"
option was added shortly after the 9Jan release.
