Hi All,
I have a question regarding using the “fix - rigid” command. I have two bodies 1 and 2. I made them interact with “LJ /cut 2.5” potential. At one stage of simulation I wanted one of the body to be rigid while the other body interacting the same as earlier. In this case, I was just wondering that if I make the body 2 rigid, do I have the interaction between the body 1 and 2 and body 1 described by “LJ /cut 2.5” ? Also in this case do I need to turn the “NVE” integration?
Thanks, in advance.
Peri.
