I'm trying to use fix shake to fix the bond length in two tri-mers (see attached data and input files) and got the following error:
LAMMPS (11 Aug 2010)
Scanning data file ...
1 = max bonds/atom
Reading data file ...
orthogonal box = (-10 -10 -10) to (10 10 10)
1 by 1 by 1 processor grid
6 atoms
4 bonds
2 = max # of 1-2 neighbors
1 = max # of 1-3 neighbors
1 = max # of 1-4 neighbors
2 = max # of special neighbors
Finding SHAKE clusters ...
*** Process received signal ***
Signal: Bus error (10)
Signal code: (2)
Failing at address: 0x4
[ 1] [0xbfffeae8, 0x00000004] (-P-)
[ 2] (_ZN9LAMMPS_NS8FixShakeC2EPNS_6LAMMPSEiPPc + 0x4d0) [0xbfffeb68, 0x000e9dd0]
[ 3] (_ZN9LAMMPS_NS6Modify7add_fixEiPPc + 0x17ce) [0xbfffebf8, 0x001283ee]
[ 4] (_ZN9LAMMPS_NS5Input15execute_commandEv + 0xda9) [0xbfffed48, 0x0010fc29]
[ 5] (_ZN9LAMMPS_NS5Input4fileEv + 0x333) [0xbffff5f8, 0x00111e83]
[ 6] (main + 0x60) [0xbffff628, 0x00118020]
[ 7] (start + 0x36) [0xbffff648, 0x00002736]
[ 8] [0x00000000, 0x00000001] (FP-)
Using backtracing in GDB, I got
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: KERN_PROTECTION_FAILURE at address: 0x00000004
0x000e7d1f in LAMMPS_NS::FixShake::find_clusters ()
(gdb) bt
#0 0x000e7d1f in LAMMPS_NS::FixShake::find_clusters ()
#1 0x000e9dd0 in LAMMPS_NS::FixShake::FixShake ()
#2 0x001283ee in LAMMPS_NS::Modify::add_fix ()
#3 0x0010fc29 in LAMMPS_NS::Input::execute_command ()
#4 0x00111e83 in LAMMPS_NS::Input::file ()
#5 0x00118020 in main ()
Am I missing something in the data file and input script? Or is there any singularity in the FixShake::find_clusters() function that my test system triggers?
(FYI, this error does not appear for dimers.)
Any suggestions/corrections are appreciated. If anyone has a simple working example of fix shake for tri-mers, could you kindly share it with me?
-Trung
in.shake (607 Bytes)
data.shake (298 Bytes)
