I am using fix viscosity command to try to obtain some information about the viscosity of a block copolymer melt. The simulation box is divided into 20 layers and the momentum flux is in y direction. However, no matter what Nswap and Nstep parameters I used, the velocity profiles, which are obtained through fix ave/spatial, indicating that only the 1st and 11th layers have a considerable velocity, whereas the velocity of the rest layers is close to zero. The initial velocities of all beads are random and I am running a DPD simulation. So may I have your opinion on this?
Thanks very much for your kind help.
Best Regards,
Weilong Zhao
from USTC
