I am using an old version of lammps (Jul17 2006) to model self-assembly of copolymer under shear. In order to calculate the radius of gyration I compile src after adding fix_gyration to the source, which was not included in that version.
Initially I did not apply the command of fix_gyration and it went well. However with the use of this fix command floating point exception occured at the very beginning of the calculation. I can not figure out why this happens. Would you please offer me some advice? (The fix_gyration source is coming from a later version.)
Sincerely,
Zhao Weilong
Department of Polymer Science and Engineering
University of Science and Technology of China
Hefei, Anhui, PRC
update to the current version of lammps and try again.
nobody will want to spend time on fixing bugs in a
hodge podge of old code. if you don't want to do this,
you are on your own.
cheers,
You're putting a file from the current version of LAMMPS into a 4-year old
version, and it isn't working? I'd be more surprised if it did work.
Please just download and try out the current version.
