[lammps-users] Force vs displacement of polypeptide
I would like to investigate the strength of various polypeptide secondary structures (beta-sheets, alpha-helix) by fixing one end of the polymer to a constant position and applying a constant velocity to the other end so the force vs displacement can be monitored.
I’m wondering if anyone has any advice in how to perform this simulation.
My initial guess is to use the fix move command with linear style in the direction I want to pull but I’m not sure how I would constrain the other end of my polymer from moving.
If you know of any tutorials or have any general help, it would be greatly appreciated.
Joe
I'm wondering if anyone has any advice in how to perform this simulation.
this sounds like a job for "fix smd"
direction I want to pull but I'm not sure how I would constrain the other
you can exclude those atoms from time integration or zero out
forces and velocities. "fix smd" would also allow a "couple" mode,
where you can pull at both ends simultaneously and thus giving
your double the statistics and no fixing of atoms required.
appreciated.
the papers referred to on the fix smd documentation have very detailed
descriptions of the steered MD process and discuss sources of errors
and accuracy as well.
cheers,
