Hi all,
I am just working on a system consisting of two types of particles with different shapes. The first kind is a simple sphere with radius one and the other one is an ellipsoid with radii 3 1 1. The potential I’m going to use is gayberne. I am confused setting the potential parameters. I have read the manual but I think it contradicts with lammps example “ellipse”. I don’t know what is the relationship between potential parameters and desired ellipsoid radii.
Let an ellipsoid have radii a b and c. Consider the following lines:
shape a b c
pair_coeff 1 * epsilon sigma x1 x2 x3 y1 y2 y3
How should I set epsilon, sigma, x1, x2 and x3 in order to apply the different radii of ellipsoid in potential?
Thank you in advance
M. Baghery
Hi all,
mehrdad,
I'm going to use is gayberne. I am confused setting the potential
lammps example "ellipse". I don't know what is the relationship
shape a b c
i would rather say that _your_ example contradicts bother
the ellipse example and what is in the LAMMPS manual.
the syntax for shape is:
shape <type> <a> <b> <c>
i.e. it takes four arguments and similarly there are
no x1 x2 x3 y1 y2 y3 parameters for the pair_coeff
command. in my (up-to-date) version of LAMMPS the ellipsoid
example matches the documentation well.
what version of LAMMPS are you using?
cheers,
I talked to Mike Brown about this. The GB standard practice
is to define sigma as the min of the 3 shape diams, though
you don't have to. This is different than the RE-squared
potential where sigma is the size of the small sphere you
are integrating over, typically 1 regardless of the size
of the much bigger ellipsoid.
Note that for I,J interactions sigma can be mixed or
specified directly with a pair_coeff command.
I've amended the doc pages to reflect this guidance.
