[lammps-users] Got error: Failed to reallocate 1265040 bytes for array atom:x
Dear Friends,
I’m using the 30Mar10 version of lammps. I have a problem.
I got errors "Failed to reallocate %d bytes for array %s" when I was running an atomic system with more than 10 milllion atoms on 128 and 256 CPUs.
The lammps manual suggests it is a memory problem:
"Your LAMMPS simulation has run out of memory. You need to run a smaller simulation or on more processors. "
What surprised me is that the above system can be run normally on 64 CPUs. And the output memory usage information is as follows:
“Memory usage per processor = 195.239 Mbytes”
The actual situation is opposite to the suggestion from the manual. Why?
Haofei Zhou
