I want to move an group of atoms, when i use fix move command the temperature increases. I don’t want to rescale the temperature. I want study the heat transfer to the group of atoms caused by surrounding environment not due to the velocity, which is added to move the group of atoms.
Can you suggests any other command by that i can move the atoms without changing the temperature?
Thanks and regards
Karthik V
