[lammps-users] Help with Error
I am receiving the following error "Expected integer parameter in input script of data file." I believe the error is in my input file, but im having trouble figuring out where I went wrong. I am new to LAMMPS, any help would be great. I attached my input file.
Thank You,
Morgan Warren
asp.in (2.16 KB)
Hi
I had the same error, LAMMPS expects integer number for some coeffs
(probably dihedrals). If you set one of those like 60.0 an intern LAMMPS
routine regards them as non integer and therefore the error occurs,
instead of 60.0 for example just try 60 .
greets
Lukas
The error is to prevent you from using 60.5 and thinking
that's what LAMMPS will use in the computation. It won't,
it will truncate to an integer.
