[lammps-users] Hi!About atoms ID
> Dear Sir:
> I was confused by the regulation of how the atoms ID is defined when building up the geometry model by using “lattice” command.When i output the parameters of a group of atoms, i can not get any patterns and can not find related description in the manual.Waiting for your help,thanks a lot~
> Regard,
> frank
If you run in parallel, then each processor’s atoms will have consecutive
IDs and then the next processor’s, etc.
So you will get different ID assignments when running on different #'s of procs.
Hi, all:
I’m trying to use reax to simulate polydimethylsiloxane (Si10C22H66O9). I used the ffield.reax file from the potential folder. I have also attached my input file. However, lammps does not seem to produce anything with this input file. If I change ‘pair_coeff * * ffield.reax 1 2 3 6’ to ‘pair_coeff * * ffield.reax 1 2 3 5’, the program run just fine. I notice that in the manual, it said that Si is temporarily removed. Then, I tried to copy all the Si parameters to replace all the S parameters, hoping replacing S with Si would solve the problem. However, it still doesn’t work. I would appreciate any suggestions! (a partial of the data file is attached too.)
Sincerely,
Tengfei Luo
What does "it doesn't work" mean? Is there
an error message?
2009/9/16 Tengfei Luo <[email protected]...>:
Hi, Steve:
It doesn't actually run MD but only copied the input file to the log file.
Here is what I got for the log file:
But if I change "pair_coeff * * ffield.reax 1 2 3 6" to "pair_coeff * * ffield.reax 1 2 3 5"
the MD went through well.
If you're saying that you edited the REAX potential file to add an element 6,
then when you access it with ffield.reax 1 2 3 6, things go bad, but not when
you use ffield.reax 1 2 3 5 and only access the elements that came
with the file ...
Then I think you must have done something invalid to the potential file.
