[lammps-users] How to calculate viscosity
Thanks Steve. Here is my follow up questions.
fix viscosity command just do exchanging momenta between two particles in different regions of the simulation box every N steps. This induces a shear velocity profile in the system. This enables a viscosity of the fluid to be calculated.
But which command can alculate the total momentum transferred?
Can you help me check the following command, if I want to output the momentum transferred by these swaps by the fix?
fix visco mobile viscosity 100 x z 20
fix 1 mobile ave/time 1 10 50 f_visco[1] f_visco[2] f_visco[3] file momentum.mobile
Thanks.
Yang
09年4月15日,周三, Steve Plimpton [email protected] 写道:
> 发件人: Steve Plimpton [email protected]
> 主题: Re: [lammps-users] How to calculate viscosity
> 收件人: “YANG LU” <luyang0309@…215…>
> 抄送: [email protected]
> 日期: 2009年4月15日,周三,下午9:17
> I would read the original Muller-Plathe paper for the
> formula. Read section 4.15 of the manual for how
> to get quantities out of fixes. Also the thermo_style
> custom command doc page.
> Steve
> 2009/4/14 YANG LU <luyang0309@…215…>:
> > Hi All
> > I want to use “fix viscosity” command to calculate polymer’s shear
> > viscosity.
> > It is mentioned in documentation that “The total momentum
> > transferred by these velocity swaps is computed by the fix and can be
> > output.
> > Dividing this quantity by time and the cross-sectional area of the
> > simulation
> > box yields a momentum flux. The ratio of momentum flux to the slope of the
> > shear
> > velocity profile is the viscosity of the fluid, in appopriate units.”
> > But I still can’t figure out how to do it.
> > Which argument is calculated in this command? How to get the momentum flux?
> > How to out put the result of a “fix” command?
> > Is there any easy way to get the shear rate mentioned above?
> > Thanks.
> > Yang
> > ________________________________
> > 好玩贺卡等你发,邮箱贺卡全新上线!
> > This SF.net email is sponsored by:
> > High Quality Requirements in a Collaborative Environment.
> > Download a free trial of Rational Requirements Composer Now!
> > http://p.sf.net/sfu/www-ibm-com
> > _______________________________________________
> > lammps-users mailing list
> > [email protected]
> > https://lists.sourceforge.net/lists/listinfo/lammps-users
Read the fix viscosity doc page. It tells you the fix stores a scalar
quantity which is the momentum you want. It also tells
you where else to read about how to extract that quantity from
the fix.
