Dear Lammps User.
Right now when I use lammps, I should enter the command like
"Lmp < in.test".
If I want put the "in.test" in the source, where should I modified.
In other words, the only command I should enter is "Lmp" and
it will read the input file "in.test" automatically.
Dear Lammps User.
"Lmp < in.test".
why the hell would you want to do that???
you can easily write your own main function.
the LAMMPS_NS::Input:::file() method is
overloaded to take either no argument
(for reading from stdin) or a filename.
