[lammps-users] how to output angle types
Dear Lammps Users:
When I use “compute angle/local” command, it can only output angle values (in degree) and energies of each angle in a system. Is there any way to also output angle types, based on those specified in the data file? This is useful while calculating distribution of certain kinds of angles. Thanks.
Shaorui Yang
Dear Lammps Users:
When I use "compute angle/local" command, it can only output angle values
you can output the angle type via the compute property/local
