[lammps-users] How to output temp/chunk data
Dear Dr Axel,
Sorry for that, I am not using the mailing list very well.
I have tried your as your suggestion and get some results like you provided.
Time-averaged data for fix 2
TimeStep Number-of-rows
Row c_Stemp
0 6
1 400.35
2 393.64
3 400.894
4 -2.9475
5 0.63814
6 5.83513
100 6
1 455.786
2 448.843
3 562.389
4 -2.61164
5 -3.40383
6 -1.25168
I found that there are only 6 rows in each step, and I have more than 6 chunks in the system. My test system is about 150A at z direction and divided in chunks every 5A. There should be 30 chunks at least. Is there anyway to output all the chunks in the system? Or I have used a wrong command to calculate chunks?
I hope to output every chunk temp like this format, I dont’t know if it is possible.
timestep0
chunk1 300
chunk2 300
chunkN 300
timestep1
chunk1 300
chunk2 300
chunkN 300
Here is the input command
lattice fcc 3.3 origin 0.0 0.0 0.0 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
region sim_box block 0 10 0 10 0 50 units lattice
compute c0 sample chunk/atom bin/1d z lower 6.6 units box
compute Stemp sample temp/chunk c0 temp com yes
fix 2 all ave/time 100 1 100 c_Stemp file tmp.out mode vector
Thank you.
Regards
Yuntian Wang
On 2/22/2021 18:58,Axel Kohlmeyer[email protected] wrote:
