Dear everyone,
As a beginner of Lammps, I am learning the use throuht the examples. But there is something difficult to solve by myself. So if possible, Could you give me some advices?
I have practised the example of CRACK which is supplied by the Lammps itself, and run the problem successful with producing the file dump.crack and log.lammps. When visualizing the dump file, it gives the introducution: Error, Cannot Open Display.
I have edited the part of Makefile of Xmovie Directory
XLIBDIR = -L/usr/X11R6/lib
to my own directory as XLIBDIR = home/umino/liyuan/lammps15-Apr08/lib with the instruction of README file.
Is there something wrong with my work? Thanks in advance.
Lyan
Dear everyone,
this is an X11 library error. it means that eather you are not
running an X server or didn't set your DISPLAY environment variable
to point to it, or that you don't have access permissions.
what kind of OS are you running on and are you running on a
local or a remote machine?
cheers,
