Hi,everyone,
In my file;I use the command:"compute 1 mobile reduce fx fy"
In my simulation,I want to output the cutting force,which means the force between the atoms of workpiece and the atoms of tool.
Question 1:
In the command,“fx” and “fy” mean what?
Assuming that the group mobile stands for the atoms of workpiece.Does “fx” stands for the force in the x-direction that the tool acts on the workpiece?Does it include the force that the atoms only in the workpiece interact with each other?
Question 2:
I’m confused.I only want to get the cutting force between tool and workpiece.How can I make that?Using which command?
And in my simulation I consider the tool as rigid body.
Thank you!
Comments below.
Hi,everyone,
Question 1:
Force in the x and y dim on the atoms in the group.
The latter, but those forces should cancel. So effectively the former.
Question 2:
What you have should work. You can also look at compute group/group.
