[lammps-users] I don't know which part my molecule file is wrong
I checked out the Types section and I got the same error before. (But I got ERROR on proc 0: Unknown section in molecule file (src/molecule.cpp:613))
Where is the “Unknown section in molecule file”?
The molecule file is
48 atoms
4 atom types
Types
1 4
2 2
3 2
4 4
5 2
6 2
7 3
8 3
9 1
10 2
11 1
12 2
13 1
14 1
15 2
16 1
17 2
18 2
19 2
20 1
21 2
22 2
23 2
24 1
25 2
26 2
27 2
28 1
29 2
30 2
31 2
32 1
33 2
34 2
35 2
36 1
37 2
38 2
39 2
40 1
41 2
42 2
43 2
44 1
45 2
46 2
47 2
48 2
Masses
1 12.0107 # C
2 1.00794 # H
3 14.0067 # N
4 28.085501 # Si
Coords
1 -1.39364 0.67237 0 # Si
2 -0.90366 -0.71356 0 # H
3 -0.90363 1.36533 -1.20025 # H
4 -0.61363 1.77545 1.9106 # Si
5 -1.10142 3.16216 1.90926 # H
6 -1.10583 1.08404 3.11085 # H
7 1.25637 1.77247 1.91231 # N
8 -3.26364 0.67239 0 # N
9 -3.75366 -0.71353 -0.00034 # C
10 -3.36253 -1.22992 -0.85196 # H
11 -3.75363 1.36566 -1.20008 # C
12 -3.36252 0.88673 -2.07333 # H
13 1.74416 1.07952 3.11347 # C
14 1.74858 3.15761 1.91184 # C
15 2.81682 3.15655 1.97314 # H
16 1.161 1.75532 4.36839 # C
17 0.27813 1.23495 4.67604 # H
18 1.884 1.72813 5.1567 # H
19 0.9157 2.77244 4.14434 # H
20 1.30073 -0.39465 3.07134 # C
21 1.34898 -0.75297 2.06427 # H
22 1.94893 -0.97989 3.68958 # H
23 0.29618 -0.47535 3.43088 # H
24 1.16566 3.90995 3.12254 # C
25 1.8218 3.79982 3.96055 # H
26 1.06461 4.9478 2.88264 # H
27 0.20557 3.50494 3.36563 # H
28 1.30967 3.85791 0.6124 # C
29 1.96452 4.67994 0.41153 # H
30 1.35136 3.16208 -0.19938 # H
31 0.30818 4.21829 0.72218 # H
32 -3.29109 2.83423 -1.16936 # C
33 -3.3145 3.19455 -0.16213 # H
34 -2.29309 2.90186 -1.54926 # H
35 -3.94431 3.42666 -1.77536 # H
36 -5.29241 1.31266 -1.23121 # C
37 -5.66294 2.08426 -1.87326 # H
38 -5.60907 0.35934 -1.59973 # H
39 -5.67435 1.45755 -0.24226 # H
40 -5.29243 -0.71393 -0.06184 # C
41 -5.66905 0.16165 0.42438 # H
42 -5.60852 -0.71809 -1.08408 # H
43 -5.66887 -1.58563 0.43143 # H
44 -3.29117 -1.42184 1.28652 # C
45 -2.29093 -1.77918 1.15718 # H
46 -3.3205 -0.73175 2.10373 # H
47 -3.94074 -2.24671 1.49277 # H
48 2.81251 1.12985 3.14514 # H
and my Si3N4 file is
LAMMPS data file written by OVITO Basic 3.4.2
208 atoms
4 atom types
0.0 15.1682033539 xlo xhi
0.0 13.1360494342 ylo yhi
0.0 22.0088653564 zlo zhi
-7.5841016769 0.0 0.0 xy xz yz
Masses
1 12.0107 # C
2 1.007940 # H
3 14.006700 # N
4 28.085501 # Si
Atoms # charge
1 2 0.0 4.531185041 0.3142901237 0.4271356899
2 2 0.0 0.7311957261 6.8697819725 0.4367035599
…(Skip)
INPUT file
LAMMPS input - silicon nitride with reaxff
units real
atom_style charge
read_data Si3N4.data
molecule BDIPAS BDIPAS.data
timestep 0.25
pair_style reax/c lmp_control
pair_coeff * * ffield.reax.SiN C H N Si
fix 1 all nvt temp 500.0 500.0 50.0
fix 2 all qeq/reax 1 0.0 10.0 1e-6 param.qeq
fix 3 BDIPAS deposit 48 1 100 1 region near 10 vz -1.0 -1.0 box
dump dp1 all atom 50 bfadd.lammpstrj
thermo 50
run 100
You should have checked out the Masses section, too. You don’t need it since masses for your system are set through the mass keyword or the data file. As the documentation for the manual explains, you need a masses section only if you have per-atom masses (and not per-type masses) and in that case you need more entries (same as for Types).
Axel.
indeed the entire file is incorrect. you seem to be confusing the format of the “molecule” file with the format of the “data” file. those are not the same.
