I was trying to dump a file after certain time step using a if command. For some unknown reason, it is starting at the very beginning for the run. Is it possible to dump like this?
variable nstep equal step
print “v_nstep”
if v_nstep > 300000 then “dump 302 all custom 100 ts111_variable.csp c_400 x y z”
no.
the typical way of doing this is to use multiple run commands.
where you define the dump _after_ the first run. if you want just
this one frame, you can use a "run 0" and undump right afterwards.
Axel is correct. The dump command in your if
statement does not perform a dump. It just defines
a dump command and file, which gets invoked
when a run is performed.
