Dear LAMMPS authors,
I tried to run a NEB calculations, and I finally succeeded once I
included an "atom_modify map" command in the input file (BTW, thanks for
the example). It is mentioned in the doc that atoms sorting must be
disabled using "atoms_modify sort", but not that mapping has to be
activated.
I did not find any messages related to this issue in the archive, so I
thought it might be worth to tell you.
Thanks for the support and for the LAMMPS code,
Laurent
