[lammps-users] Insallation probelm of REAX package on Bluegene
Dear users:
I am trying to install LAMMPS with REAX package on Bluegene cluster. I have successfully done this job on other kinds of clusters, but I couldn't do this on Bluegene. I could installed LAMMPS without REAX on Bluegene. So it seems that there is a problem with linking of REAX code which is written with FORTRAN to the main code of LAMMPS which is a C++ code.
My question is whether there is any special flag setting required for the "reax_SYSLIB" or any other option?
The error which I receive is as follows.
/home/lammps-16Apr10/lib/reax/reax_reac.F:130: more undefined references to `do_lio' follow
/home/lammps-16Apr10/lib/reax/reax_reac.F:130: undefined reference to `e_wsle'
and some similar errors.
I have also included the related part of my Makefile for reax package.
reax_SYSLIB = -lifcore -lsvml -lompstub -limf
or
reax_SYSLIB = -lreax
reax_SYSPATH = -L/home/lammps-16Apr10/lib/reax
I appreciate in advance any help.
Thanks.
Farshad Saberi
Mechanical Engineering Department, UAB
Dear users:
a C++ code.
compiling on a blue gene requires special care and knowledge about
the hard and software. first of all, you have to be aware that you
have to do a cross compilation. that is particularly an issue for
the library files.
this looks like you compiled the library with a fortran compiler
than doesn't match the runtime libraries that you provide when
linking the whole binary.
this is nonsense. those files are for intel fortran, you'll have
to figure out what would be the corresponding runtime libraries
for the bluegene runtime environment. have a look at the documentation
and search for how you should link c++ and fortran codes into one
executable.
or
i strongly suggest to consult with your local support staff
for the machine. i have compiled on BG/Ls before, and some
of the stuff is not easy to comprehend for somebody that
is not well accustomed for using those.
with reference to previous recent discussions on the list
about (static) memory requirements for reaxx, i would also
be concerned that you need to adjust parameters in the fortran
part to be able to run at all, since blue gene machines don't
tend to have that much local memory on the node cards...
cheers,
Thank you a lot for your help.
Do you know any free opensource software that I can use to extract fragments data from the bonds/reax file? I'm concerned with getting information regarding bond cleavage and formation and species formed after reactive MD simulation by LAMMPS/REAX?
Farshad
