Hello sir
Can you help me why following errors are coming?
make g++
Makefile:93: compute_temp.d: No such file or directory
Makefile:93: compute_temp_deform.d: No such file or directory
Makefile:93: compute_temp_partial.d: No such file or directory
Makefile:93: compute_temp_profile.d: No such file or directory
Makefile:93: compute_temp_ramp.d: No such file or directory
Makefile:93: compute_temp_region.d: No such file or directory
Makefile:93: compute_temp_sphere.d: No such file or directory
Makefile:93: create_atoms.d: No such file or directory
Makefile:93: create_box.d: No such file or directory
Makefile:93: delete_atoms.d: No such file or directory
Makefile:93: delete_bonds.d: No such file or directory
Makefile:93: dihedral_charmm.d: No such file or directory
Makefile:93: dihedral.d: No such file or directory
Makefile:93: dihedral_harmonic.d: No such file or directory
Makefile:93: dihedral_helix.d: No such file or directory
Makefile:93: dihedral_hybrid.d: No such file or directory
Makefile:93: dihedral_multi_harmonic.d: No such file or directory
Makefile:93: dihedral_opls.d: No such file or directory
Makefile:93: displace_atoms.d: No such file or directory
Makefile:93: displace_box.d: No such file or directory
Makefile:93: domain.d: No such file or directory
Makefile:93: dump_atom.d: No such file or directory
Makefile:93: dump_cfg.d: No such file or directory
Makefile:93: dump.d: No such file or directory
Makefile:93: dump_custom.d: No such file or directory
Makefile:93: dump_dcd.d: No such file or directory
Makefile:93: dump_local.d: No such file or directory
Makefile:93: dump_xyz.d: No such file or directory
Makefile:93: error.d: No such file or directory
Makefile:93: ewald.d: No such file or directory
Makefile:93: fft3d.d: No such file or directory
Makefile:93: fft3d_wrap.d: No such file or directory
Makefile:93: finish.d: No such file or directory
Makefile:93: fix_addforce.d: No such file or directory
Makefile:93: fix_ave_atom.d: No such file or directory
Makefile:93: fix_aveforce.d: No such file or directory
Makefile:93: fix_ave_histo.d: No such file or directory
Makefile:93: fix_ave_spatial.d: No such file or directory
Makefile:93: fix_ave_time.d: No such file or directory
Makefile:93: fix_bond_break.d: No such file or directory
Makefile:93: fix_bond_create.d: No such file or directory
Makefile:93: fix_bond_swap.d: No such file or directory
Makefile:93: fix_box_relax.d: No such file or directory
Makefile:93: fix.d: No such file or directory
Makefile:93: fix_deform.d: No such file or directory
Makefile:93: fix_deposit.d: No such file or directory
Makefile:93: fix_drag.d: No such file or directory
Makefile:93: fix_dt_reset.d: No such file or directory
Makefile:93: fix_efield.d: No such file or directory
Makefile:93: fix_enforce2d.d: No such file or directory
Makefile:93: fix_evaporate.d: No such file or directory
Makefile:93: fix_gravity.d: No such file or directory
Makefile:93: fix_heat.d: No such file or directory
Makefile:93: fix_indent.d: No such file or directory
Makefile:93: fix_langevin.d: No such file or directory
Makefile:93: fix_lineforce.d: No such file or directory
Makefile:93: fix_minimize.d: No such file or directory
Makefile:93: fix_momentum.d: No such file or directory
Makefile:93: fix_move.d: No such file or directory
Makefile:93: fix_nph.d: No such file or directory
Makefile:93: fix_npt.d: No such file or directory
Makefile:93: fix_npt_sphere.d: No such file or directory
Makefile:93: fix_nve.d: No such file or directory
Makefile:93: fix_nve_limit.d: No such file or directory
Makefile:93: fix_nve_noforce.d: No such file or directory
Makefile:93: fix_nve_sphere.d: No such file or directory
Makefile:93: fix_nvt.d: No such file or directory
Makefile:93: fix_nvt_sllod.d: No such file or directory
Makefile:93: fix_nvt_sphere.d: No such file or directory
Makefile:93: fix_orient_fcc.d: No such file or directory
Makefile:93: fix_planeforce.d: No such file or directory
Makefile:93: fix_press_berendsen.d: No such file or directory
Makefile:93: fix_print.d: No such file or directory
Makefile:93: fix_recenter.d: No such file or directory
Makefile:93: fix_respa.d: No such file or directory
Makefile:93: fix_rigid.d: No such file or directory
Makefile:93: fix_set_force.d: No such file or directory
Makefile:93: fix_shake.d: No such file or directory
Makefile:93: fix_shear_history.d: No such file or directory
Makefile:93: fix_spring.d: No such file or directory
Makefile:93: fix_spring_rg.d: No such file or directory
Makefile:93: fix_spring_self.d: No such file or directory
Makefile:93: fix_store_coord.d: No such file or directory
Makefile:93: fix_store_force.d: No such file or directory
Makefile:93: fix_temp_berendsen.d: No such file or directory
Makefile:93: fix_temp_rescale.d: No such file or directory
Makefile:93: fix_thermal_conductivity.d: No such file or directory
Makefile:93: fix_tmd.d: No such file or directory
Makefile:93: fix_ttm.d: No such file or directory
Makefile:93: fix_viscosity.d: No such file or directory
Makefile:93: fix_viscous.d: No such file or directory
Makefile:93: fix_wall.d: No such file or directory
Makefile:93: fix_wall_harmonic.d: No such file or directory
Makefile:93: fix_wall_lj126.d: No such file or directory
Makefile:93: fix_wall_lj93.d: No such file or directory
Makefile:93: fix_wall_reflect.d: No such file or directory
Makefile:93: fix_wall_region.d: No such file or directory
Makefile:93: force.d: No such file or directory
Makefile:93: group.d: No such file or directory
Makefile:93: improper.d: No such file or directory
Makefile:93: improper_cvff.d: No such file or directory
Makefile:93: improper_harmonic.d: No such file or directory
Makefile:93: improper_hybrid.d: No such file or directory
Makefile:93: input.d: No such file or directory
Makefile:93: integrate.d: No such file or directory
Makefile:93: kspace.d: No such file or directory
Makefile:93: lammps.d: No such file or directory
Makefile:93: lattice.d: No such file or directory
Makefile:93: library.d: No such file or directory
Makefile:93: main.d: No such file or directory
Makefile:93: memory.d: No such file or directory
Makefile:93: min_cg.d: No such file or directory
Makefile:93: min.d: No such file or directory
Makefile:93: min_hftn.d: No such file or directory
Makefile:93: minimize.d: No such file or directory
Makefile:93: min_linesearch.d: No such file or directory
Makefile:93: min_sd.d: No such file or directory
Makefile:93: modify.d: No such file or directory
Makefile:93: neigh_bond.d: No such file or directory
Makefile:93: neighbor.d: No such file or directory
Makefile:93: neigh_derive.d: No such file or directory
Makefile:93: neigh_full.d: No such file or directory
Makefile:93: neigh_gran.d: No such file or directory
Makefile:93: neigh_half_bin.d: No such file or directory
Makefile:93: neigh_half_multi.d: No such file or directory
Makefile:93: neigh_half_nsq.d: No such file or directory
Makefile:93: neigh_list.d: No such file or directory
Makefile:93: neigh_request.d: No such file or directory
Makefile:93: neigh_respa.d: No such file or directory
Makefile:93: neigh_stencil.d: No such file or directory
Makefile:93: output.d: No such file or directory
Makefile:93: pack.d: No such file or directory
Makefile:93: pair_airebo.d: No such file or directory
Makefile:93: pair_born_coul_long.d: No such file or directory
Makefile:93: pair_buck_coul_cut.d: No such file or directory
Makefile:93: pair_buck_coul_long.d: No such file or directory
Makefile:93: pair_buck.d: No such file or directory
Makefile:93: pair_coul_cut.d: No such file or directory
Makefile:93: pair_coul_debye.d: No such file or directory
Makefile:93: pair_coul_long.d: No such file or directory
Makefile:93: pair.d: No such file or directory
Makefile:93: pair_dpd.d: No such file or directory
Makefile:93: pair_eam_alloy.d: No such file or directory
Makefile:93: pair_eam.d: No such file or directory
Makefile:93: pair_eam_fs.d: No such file or directory
Makefile:93: pair_hybrid.d: No such file or directory
Makefile:93: pair_hybrid_overlay.d: No such file or directory
Makefile:93: pair_lj96_cut.d: No such file or directory
Makefile:93: pair_lj_charmm_coul_charmm.d: No such file or directory
Makefile:93: pair_lj_charmm_coul_charmm_implicit.d: No such file or directory
Makefile:93: pair_lj_charmm_coul_long.d: No such file or directory
Makefile:93: pair_lj_cut_coul_cut.d: No such file or directory
Makefile:93: pair_lj_cut_coul_debye.d: No such file or directory
Makefile:93: pair_lj_cut_coul_long.d: No such file or directory
Makefile:93: pair_lj_cut_coul_long_tip4p.d: No such file or directory
Makefile:93: pair_lj_cut.d: No such file or directory
Makefile:93: pair_lj_expand.d: No such file or directory
Makefile:93: pair_lj_gromacs_coul_gromacs.d: No such file or directory
Makefile:93: pair_lj_gromacs.d: No such file or directory
Makefile:93: pair_lj_smooth.d: No such file or directory
Makefile:93: pair_morse.d: No such file or directory
Makefile:93: pair_soft.d: No such file or directory
Makefile:93: pair_sw.d: No such file or directory
Makefile:93: pair_table.d: No such file or directory
Makefile:93: pair_tersoff.d: No such file or directory
Makefile:93: pair_tersoff_zbl.d: No such file or directory
Makefile:93: pair_yukawa.d: No such file or directory
Makefile:93: pppm.d: No such file or directory
Makefile:93: pppm_tip4p.d: No such file or directory
Makefile:93: random_mars.d: No such file or directory
Makefile:93: random_park.d: No such file or directory
Makefile:93: read_data.d: No such file or directory
Makefile:93: read_restart.d: No such file or directory
Makefile:93: region_block.d: No such file or directory
Makefile:93: region_cone.d: No such file or directory
Makefile:93: region.d: No such file or directory
Makefile:93: region_cylinder.d: No such file or directory
Makefile:93: region_intersect.d: No such file or directory
Makefile:93: region_plane.d: No such file or directory
Makefile:93: region_prism.d: No such file or directory
Makefile:93: region_sphere.d: No such file or directory
Makefile:93: region_union.d: No such file or directory
Makefile:93: remap.d: No such file or directory
Makefile:93: remap_wrap.d: No such file or directory
Makefile:93: replicate.d: No such file or directory
Makefile:93: respa.d: No such file or directory
Makefile:93: run.d: No such file or directory
Makefile:93: set.d: No such file or directory
Makefile:93: shell.d: No such file or directory
Makefile:93: special.d: No such file or directory
Makefile:93: temper.d: No such file or directory
Makefile:93: thermo.d: No such file or directory
Makefile:93: timer.d: No such file or directory
Makefile:93: universe.d: No such file or directory
Makefile:93: update.d: No such file or directory
Makefile:93: variable.d: No such file or directory
Makefile:93: velocity.d: No such file or directory
Makefile:93: verlet.d: No such file or directory
Makefile:93: write_restart.d: No such file or directory
g++ -g -DFFT_FFTW -I…/STUBS -I…/localfft/include -DLAMMPS_GZIP -DMPICH_IGNORE_CXX_SEEK -I/opt/mpich2/include -DFFT_FFTW -M write_restart.cpp > write_restart.d
Manisha.
