To whom it may concern:
I'm trying to analyse a nearly 2D atomic configurations from LAMMPS MD run.
Is there any tools that can locate the peaks from the xyz?
run.
sounds like a job for VMD scripting:
http://www.ks.uiuc.edu/Research/vmd
cheers,
Thank you for the info.
I'm going to study this.
Y. Lin
What does peaks from xyz mean?
A nearly 2D xyz file looks like a membrane. During MD simulation, the membrane won't stay in the perfect 2D plane. Therefore there must be peaks and valleys.
Y. Lin
