Dear all
I want to simulate some behaviors on various surface orientations of Au.
I used “lattice orient” command and succeeded in calculation, however, I found that potential energy of each atom was not correct.
The input script is as follows:
atom_style atomic
lattice fcc 4.08 orient x 1 -1 0 orient y 1 1 -2 orient z 1 1 1
region space block 0.0 10.0 0.0 10.0 0.0 10.0
create_box 1 space
create_atoms 1 region space
mass 1 196.97
pair_style eam
pair_coeff * * ./Au_u3.eam
compute Au_temp all temp
compute eng all pe/atom
fix 1 all nve
fix 2 all temp/rescale 100 300 300 5.0 0.9
thermo 100
thermo_style custom step atoms temp pe
thermo_modify norm yes
dump Posidump all custom 1000 300kAu_111_*.dat type x y z c_eng
timestep 0.001
run 10000
And the summarized dump file at the zero step is as follows:
ITEM: TIMESTEP
0
ITEM: NUMBER OF ATOMS
15839
ITEM: BOX BOUNDS
0 57.6999
0 66.6261
0 70.6677
ITEM: ATOMS
-> 1 5.76999 14.9909 0 -3.62013
-> 1 7.21249 12.4924 0 -3.92694
-> 1 4.32749 12.4924 0 -3.84706
-> 1 0 14.9909 0 -3.61885
-> 1 1.4425 12.4924 0 -3.74341
-> 1 4.32749 14.1581 2.35559 -3.83265
1 5.76999 14.9909 7.06677 -3.93
1 5.76999 11.6596 9.42236 -3.93
1 4.32749 9.16109 9.42236 -3.93
-> 1 2.885 0 0 -1.0259
-> 1 5.76999 0 0 -1.02579
In principle, all energies of Au should be 3.93 eV, but, some atoms show wrong value. (‘->’ line)
I guess that the problem is originated from a kind of round-off error.
How do you think about this issue?
Thanks in advance.
Sang-Pil
