[lammps-users] Lammps and opensuse 11.2
Hi , i was trying to make a new installation of lammps in opensuse 11.2 with gpu. I haven’t installed lammps ever before in an opensuse linux.
I did the same things ; installed mpich2 , fftw2.1 in usr/local/mpichmpich2-1.2.1 and usr/local/fftw-2.1.5 respectively. I then took the file makefile.g++ ,because there is no more an opensuse make file and i wrote something like this:
SHELL = /bin/sh
MPI_INC =/usr/local/mpich2-1.2.1/include
#MPI_PATH = /usr/local/mpich2-1.2.1/bin
MPI_LIB =/usr/local/mpich2-1.2.1/lib
FFTW_INC=/usr/local/fftw-2.1.5/include
FFTW_LIB=/usr/local/fftw-2.1.5/lib
CC = g++
CCFLAGS = -g -O -I$(MPI_INC) -I$(FFTW_INC)
-DFFT_FFTW -DGZIP
-DMPICH_IGNORE_CXX_SEEK
DEPFLAGS = -M
LINK = g++
LINKFLAGS = -g -O -L$(MPI_LIB) -L$(FFTW_LIB)
USRLIB = -lmpi -lfftw
#-lpthread -lmpi_cxx
SYSLIB =
ARCHIVE = ar
ARFLAGS = -rc
SIZE = size
LAMMPS-specific settings
specify settings for LAMMPS features you will use
LAMMPS ifdef options, see doc/Section_start.html
MPI library, can be src/STUBS dummy lib
INC = path for mpi.h, MPI compiler settings
PATH = path for MPI library
LIB = name of MPI library
FFT library, can be -DFFT_NONE if not using PPPM from KSPACE package
INC = -DFFT_FFTW, -DFFT_INTEL, -DFFT_NONE, etc, FFT compiler settings
PATH = path for FFT library
LIB = name of FFT library
System-specific settings
#FFT_PATH =
additional system libraries needed by LAMMPS package libraries
these settings are IGNORED if the corresponding LAMMPS package
(e.g. gpu, meam) is NOT included in the LAMMPS build
SYSLIB = names of libraries
SYSPATH = paths of libraries
gpu_SYSLIB = -lcudart
meam_SYSLIB = -lifcore -lsvml -lompstub -limf
reax_SYSLIB = -lifcore -lsvml -lompstub -limf
user-atc_SYSLIB = -lblas -llapack
gpu_SYSPATH = -L/usr/local/cuda/lib64
meam_SYSPATH = -L/opt/intel/fce/10.0.023/lib
reax_SYSPATH = -L/opt/intel/fce/10.0.023/lib
user-atc_SYSPATH =
build rules and dependencies
no need to edit this section
include Makefile.package
EXTRA_INC = (LMP_INC) (PKG_INC) (MPI_INC) (FFT_INC)
EXTRA_PATH = (PKG_PATH) (MPI_PATH) (FFT_PATH) (PKG_SYSPATH)
EXTRA_LIB = (PKG_LIB) (MPI_LIB) (FFT_LIB) (PKG_SYSLIB)
Link target
(EXE): (OBJ)
(LINK) (LINKFLAGS) (EXTRA_PATH) (OBJ) (EXTRA_LIB) (LIB) -o (EXE) (SIZE) $(EXE)
Library target
lib: (OBJ) (ARCHIVE) (ARFLAGS) (EXE) $(OBJ)
Compilation rules
.o:.cpp
(CC) (CCFLAGS) (EXTRA_INC) -c <
.d:.cpp
(CC) (CCFLAGS) (EXTRA_INC) (DEPFLAGS) < > @
Individual dependencies
DEPENDS = (OBJ:.o=.d) include (DEPENDS)
Did it work or do you have a question?
2010/4/28 Jim Jim <[email protected]...>:
No it didn’t.It says during the making a lot of:
g++: /usr/local/mpich2-1.2.1/include: linker input file unused because linking not done
and at the end
/usr/local/mpich2-1.2.1/lib: file not recognized: Is a directory
collect2: ld returned 1 exit status
make[1]: *** […/lmp_g++] Error 1
make[1]: Leaving directory `/home/dimitris/Desktop/lammps-26Apr10/src/Obj_g++’
make: *** [g++] Error 2
This error means you didn't specify the link path and MPI library
file correctly - you need to find where it is on your system and
make sure the -L and -l (small L) settings are correct on your box.
Then look at the link link echoed by the Makefile, and make sure
the settings appear as you think you specified them.
