[lammps-users] LAMMPS install
Dear LAMMPS users,
I am having a problem installing LAMMPS for my intel machine running CentOS 4. I want to install a serial version that can utilize the Reax force field. I did the following steps
in lib/reax I ran make -f Makefile.ifort and I indeed get the libreax.a file
in src/STUBS I ran make and I indeed get the libmpi.a file
then in src I ran make serial
This runs for awhile but ends with the following error.
/usr/bin/ld: cannot find -lifcore
collect2: ld returned 1 exit status
make[1]: *** […/lmp_serial] Error 1
make[1]: Leaving directory `/usr/local/lammps/src/Obj_serial’
make: *** [serial] Error 2
My understanding is that the lifcore library is necessary when using C++ and Fortran code together and it should be available with the Ifort compiler. Does anyone have any suggestions for how to fix this problem? I thank you in advance for any help you can provide me with.
Jacob Harvey
Dear LAMMPS users,
make[1]: *** [../lmp_serial] Error 1
make[1]: Leaving directory `/usr/local/lammps/src/Obj_serial'
you have to adjust the makefile to tell the linker where to find the
libifcore library,
i.e. where your intel compiler installation is.
Axel,
Thank you for your help. I edited the “reax_SYSPATH =” line to be the location of the Ifort libraries and the compilation went perfectly. Thanks again helping me out on this!
Jacob
