Dear Friends
In want to install the newest version of LAMMPS on my laptop and my PC using the following way.
In lammps folder I type the following sentence
sudo apt-get install gcc fftw2 mpi-default-dev mpi-default-bin
and then I receive the following:
Reading package lists… Done
Building dependency tree
Reading state information… Done
gcc is already the newest version.
fftw2 is already the newest version.
mpi-default-dev is already the newest version.
mpi-default-bin is already the newest version.
The following packages were automatically installed and are no longer required:
libresid-builder0c2a libavformat52 libcue1 libao2 libsidplay2 libid3tag0
libmms0 libfaad2
Use ‘apt-get autoremove’ to remove them.
0 upgraded, 0 newly installed, 0 to remove and 308 not upgraded.
then in src folder I type “make openmpi”
In my PC when I want to install LAMMPS in this way I receive the following messages when I type “ sudo apt-get install gcc fftw2 mpi-default-dev mpi-default-bin ”
libmms0 libfaad2
and when in src folder I type “make openmpi” I receive a lot of warnings, and when I want run a simulation box including some water molecules I receive the following error, but I can run the simulation box without any error.
ERROR: Out of range atoms - cannot compute PPPM
My PC is a quad core PC but I did not install LAMMPS parallel.
Would you please help me about installation LAMMPS in my PC?
Saly
