Sorry about my question I am new in system please help
I need to know how to install lammpus in our parallel system (rocks cluster 7.4 )
Thanks & Regards
Sandip Saha
Thanks & Regards
Sandip Saha
There are detailed instructions for configuring, compiling, and installing LAMMPS in the manual.
For users with limited technical experience we recommend using the cmake/cmake3 procedure.
Axel
Hello Axel,
Thanks for your help
I am not found any document for how to install in hpc environment (rocks 7.4)
Can you please help me with any link for documentation
Please help
As far as the operating system is concerned, a rocks cluster is just another machine running CentOS Linux and LAMMPS is an HPC application.
There don’t need to be any specific instructions. The generic ones work just fine.
If you cannot comprehend the (detailed!!) explanations in the LAMMPS manual, you need to get help from somebody local that can.
Axel.
again, you need to study the documentation. this time for the environment module (or lmod) software.
since those are not LAMMPS, this is off-topic for this mailing list.
Hello Axel,
I am successfully build and some testing program is running
But I need small help how to make module in my environment
So I am module avli and load LAMMPS.
Thanks & Regards
Sandip Saha
