[lammps-users] LAMMPS installation
Hello sir
Following is Makefile.linux
linux = RedHat Linux box, Intel icc, MPICH3, FFTW
SHELL = /bin/sh
compiler/linker settings
specify flags and libraries needed for your compiler
CC = mpicc
CCFLAGS = -O
DEPFLAGS = -M
LINK = mpicc
LINKFLAGS = -O
LIB = -lstdc++
ARCHIVE = ar
ARFLAGS = -rc
SIZE = size
LAMMPS-specific settings
specify settings for LAMMPS features you will use
LAMMPS ifdef options, see doc/Section_start.html
LMP_INC = -DLAMMPS_GZIP
MPI library, can be src/STUBS dummy lib
INC = path for mpi.h, MPI compiler settings
PATH = path for MPI library
LIB = name of MPI library
MPI_INC = -DMPICH_IGNORE_CXX_SEEK -L/opt/mpich2/include
MPI_PATH = -L/opt/mpich2/lib
MPI_LIB = -lmpich -lpthread
FFT library, can be -DFFT_NONE if not using PPPM from KSPACE package
INC = -DFFT_FFTW, -DFFT_INTEL, -DFFT_NONE, etc, FFT compiler settings
PATH = path for FFT library
LIB = name of FFT library
FFT_INC = -DFFT_FFTW -I/opt/compiler/mkl/include/fftw
FFT_PATH = -L/opt/library/fftw-3.2.2/lib
FFT_LIB = -lfftw3
additional system libraries needed by LAMMPS package libraries
these settings are IGNORED if the corresponding LAMMPS package
(e.g. gpu, meam) is NOT included in the LAMMPS build
SYSLIB = names of libraries
Link target
(EXE): (OBJ)
(LINK) (LINKFLAGS) (EXTRA_PATH) (OBJ) (EXTRA_LIB) (LIB) -o (EXE) (SIZE) $(EXE)
Library target
lib: (OBJ) (ARCHIVE) (ARFLAGS) (EXE) $(OBJ)
Compilation rules
.o:.cpp
(CC) (CCFLAGS) (EXTRA_INC) -c <
.d:.cpp
(CC) (CCFLAGS) (EXTRA_INC) (DEPFLAGS) < > @
Individual dependencies
DEPENDS = (OBJ:.o=.d) include (DEPENDS)
SYSPATH = paths of libraries
gpu_SYSLIB = -lcudart
meam_SYSLIB = -lifcore -lsvml -lompstub -limf
reax_SYSLIB = -lifcore -lsvml -lompstub -limf
user-atc_SYSLIB = -lblas -llapack
gpu_SYSPATH = -L/usr/local/cuda/lib64
meam_SYSPATH = -L/opt/intel/fce/10.0.023/lib
reax_SYSPATH = -L/opt/intel/fce/10.0.023/lib
user-atc_SYSPATH =
build rules and dependencies
no need to edit this section
include Makefile.package
EXTRA_INC = (LMP_INC) (PKG_INC) (MPI_INC) (FFT_INC)
EXTRA_PATH = (PKG_PATH) (MPI_PATH) (FFT_PATH) (PKG_SYSPATH)
universe.o update.o variable.o velocity.o verlet.o write_restart.o -lmpich
-lpthread -lfftw3 -lstdc++ -o ../lmp_linux
you are linking to fftw-3 but lammps requires fftw-2
