Dear LAMMPS users,
I want to use
lattice sq2
like in the NEMD example input file. However I don't understand the lattice documentation for LJ units:
** For unit style /lj/, the scale argument is the Lennard-Jones reduced density, typically written as rho*. **
Q: In this sq2 case is rho* the number density (per unit area) of the two basis atoms?
Q: What is the difference between rho and rho*?
** Effectively, this means that if LJ particles of size sigma = 1.0 are used in the simulation, the lattice of particles will be at the desired reduced density. **
Q: Does the size of particles mean it's diameter? How could the diameter of the particle be sigma if the lattice constant is sigma as well?
Q: Does the lattice command set the diameter of particles?
Q: Does the behaviour of the lattice command change , when I define the create_box region in box units rather than lattice units?
With kind regards,
Thomas Wagner.
