I am currently playing around with creating binary alloys. I am relatively new to using LAMMPS and i was wondering if the following commands are correct in generating an initial structure of NiAl.
This looks reasonable. It seems to be a BCC lattice, alternating between Al and Ni. If you are using a published potential, you can just compare LAMMPS results with published results. Visualization will also work, since presumably you know what the crystal is supposed to look like.
The dimensions in the region command seem wrong, because normally these should be integers, if you want a structure that is a periodic crystal. If the cubic crystal dimensions need to be strained, you can scale a1,a2,a3 appropriately.
