[lammps-users] Lattice constant of High Entropy Alloy
I am trying to characterize main thermodynamic properties of a high entropy alloy with a meam potential. I am mainly interested in the definition of the system pe, avg lattice constant and rdf @ 300 K, for different alloy compositions. I am running a simulation like this:
atom_style atomic
atom_modify map array
lattice fcc 3.68
region whole block 0 40 0 40 0 40
create_box 5 whole
lattice fcc 3.68 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
create_atoms 1 region whole
variable fMn equal 0.20
variable fNi equal (1-${fMn})/4
variable fCr equal (1-${fMn})/4
variable fFe equal (1-${fMn})/4
set type 1 type/fraction 2 $((v_fNi+v_fCr+v_fFe+v_fMn)) 5467
set type 2 type/fraction 3 $((v_fCr+v_fFe+v_fMn)/(v_fNi+v_fCr+v_fFe+v_fMn)) 6556
set type 3 type/fraction 4 $((v_fFe+v_fMn)/(v_fCr+v_fFe+v_fMn)) 7754
set type 4 type/fraction 5 $(v_fMn/(v_fFe+v_fMn)) 8574
pair_style meam/c
pair_coeff * * library.meam Co Ni Cr Fe Mn CoNiCrFeMn.meam Co Ni Cr Fe Mn
compute csym all centro/atom bcc
compute myRDF all rdf 500 1 1 2 2 cutoff 4.8
thermo 1000
thermo_style custom step pe lx ly lz press pxx pyy pzz
velocity all create 300.0 548494 rot yes dist gaussian
fix 1 all npt temp 300 300 0.1 iso 1 1 1
run 50000
minimize 1e-10 1e-10 10000 10000
unfix 1
reset_timestep 0
fix 4 all ave/time 100 1 100 c_myRDF[*] file my_rdf.txt mode vector
run 100
unfix 4
variable mype equal pe
variable real_ao equal “lx/40”
print ${mype} append PE.data
print ${real_ao} append lattice.data
As far as I know, pe should stabilize around a certain value while pressure should stabilize around 0 (or 1 in my case), in order to consider a system relaxed. However, while my pe does stabilize, my pressure starts at about -1e5 bar at the first timestep and then fluctuates between -200 and 100 bar, it goes like this . Is it sufficient to consider the system stable or there is something wrong with the model? Thank you.
Cheers,
Stefano
please see the mailing list archives on previous discussions about pressure fluctuations.
