[lammps-users] LJ potential Parameter
Hi
I’m trying to make Cu-Zr metallic glass using LJ(12-6)potential.
I used both 12-6 and 8-4 LJ potential and calculated bulk moduluse.
In Cu case, calculated bulk moduluse is about 4 times greater than reference.
and in Zr case, calculated bulk modulus is about 10 time greater than reference…
I think the parameter value is wrong,
But i don’t know what is wrong …
If somebody had used LJ potential, can you check if my parameter is wrong or not …
The parameter which i used is listed below
Thanks!!!
