Hi everyone,
I have a questions on computing temperature. In the lammps compute commands, there is a function to compute the global temperature. I am wondering is there a way to compute the local temperature for each atom in the simulated system? Thanks.
Regards,
Jane
Hi everyone,
hi jane,
there is not such thing as a per atom temperature.
temperature is a property of an ensemble.
what you want to look at is most likely the per
atom _velocity_ (or its kinetic energy which can
be easily computed from the velocity). this can
be output easily via a custom dump.
cheers,
The compute ke/atom command will tally the KE for
each atom. It can be dumped via the custom dump command
or averaged over time via fix ave/atom, etc.
