Hi LAMMPS users,
When I used a table potential, some atoms are lost. From the output of thermo variables, I can’t see anything to cause it. Could anyone give me a suggestion? The following is part of output:
LAMMPS (22 Jan 2008)
Reading restart file …
orthogonal box = (-341.024 -327.738 -0.5) to (341.024 327.738 0.5)
2 by 2 by 1 processor grid
5500 atoms
500 atoms in group colloid
5000 atoms in group counterIon
Resetting global state of Fix 1 Style nvt from restart file info
Setting up run …
Memory usage per processor = 1.73258 Mbytes
Step Temp Press PotEng KinEng E_coul E_vdwl E_pair
155000 1 0.01064135 -0.32454778 0.99972727 -0.32438558 -0.00016220134 -0.32454778
155050 0.99999658 0.01064125 -0.32455643 0.99972386 -0.3243945 -0.00016193478 -0.32455643
155100 0.99999316 0.010641491 -0.32451056 0.99972044 -0.32434887 -0.00016169869 -0.32451056
155150 0.99998974 0.010641626 -0.32448292 0.99971701 -0.32432141 -0.00016151572 -0.32448292
155200 0.9999863 0.010641845 -0.32444333 0.99971358 -0.32428194 -0.00016139212 -0.32444333
183700 1.0010029 0.010657083 -0.32265364 1.0007299 -0.32252983 -0.00012380814 -0.32265364
183750 1.001016 0.010657055 -0.3226365 1.000743 -0.32251388 -0.00012261762 -0.3226365
183800 1.0010291 0.010657158 -0.32260134 1.0007561 -0.32247972 -0.00012162175 -0.32260134
ERROR: Lost atoms: original 5500 current 5498
my input script is:
2-d Colloidal anions with small counterions.
#initialization section
units lj #default
dimension 2
#processors 1
atom_style charge
atom definition section by reading data files
##pair_style lj/cut/coul/cut 2.5 17.5
read_restart restart.155000.NPT
##read_data restart.data
LJ potentials #epslong sigma cutoff
pair_style hybrid/overlay coul/cut 100.5 table linear 1000
pair_coeff 1 1 coul/cut 100.5
pair_coeff 1 1 table U_col_col U_col_col
pair_coeff 2 2 coul/cut 10
pair_coeff 2 2 table U_ion_ion U_ion_ion
pair_coeff 1 2 coul/cut 60.247
pair_coeff 1 2 table U_col_ion U_col_ion
pair_modify shift yes
kspace_style pppm 0.0005
kspace_modify slab 3.0
#setting simulation parameters
neighbor 1.5 multi
neigh_modify check yes
define groups
group colloid type 1
group counterIon type 2
initial velocities
#compute colloid_temp colloid temp
#compute ion_temp counterIon temp
velocity all create 1.0 482748 #generate temperature by random seed
#fix 1 all nve
fix 1 all nvt 1.0 1.0 0.3 ###aniso 0.01 1.0 0.01 1.0 NULL NULL 1.2
fix 2 all enforce2d
###fix 3 all temp/rescale 100 1.0 1.0 0.05 1.0
Run
timestep 0.00003
thermo 50
thermo_style custom step temp press pe ke ecoul evdwl epair ### lx ly lz vol
dump 1 all atom 50 npt.lammpstrj
dump 2 all atom 10000 snapshots..lammpstrj
restart 10000 restart..NVT
log log.npt_cut
run 100000
write_restart restart.afterNVT.*
Have a nice day!
Dongsheng
