Thank you for your advice.
I've tried to using make clean and then make. It is out of use. I also re-extract the whole directory for pymol_ashphere and with the same error again.
But if I install it in cygwin it works well. So I think it should caused by the compiler environment in SUSE. However I can not found how to fix it after a week searching.
