Hello everyone,
I just wanted to add a couple of things when compiling LAMMPS on Windows that are not listed in the notes in src\make\windows
- add the line #include “erfc.h” in the following files:
pair_coul_long.cpp
pair_lj_charmm_coul_long.cpp
pair_lj_cut_coul_long.cpp
disable dump DCD in style.h
I’m using Visual Studio 2008 in a Win XP and if I don’t disable this option the code does not compile. -
in read_restart.cpp comment line
#include “dirent.h”
then comment lines 323 to 340
I’m not using read_restart in Windows runs so even though this allows the code to compile successfully I don’t necessarily know what this will do if you use this command in windows
Jaime
