[lammps-users] Max number of atoms for read_data command
Hi - is there a limit on the number of atoms that can be read in using the read_data command? I get a seg fault on a configuration between the 2.3 millionth and 2.4 millionth atoms.
It is not atom/configuration dependent, as I have swapped the order of the first and second half and get the same seg fault going past that number.
I tried spliting the configuration and doing multiple read_data, but that is not permitted either.
I will try a read_restart but that would be at best a workaround. It's also possible that I could convert the data file into create_atom commands, but that is also not optimum.
  Any ideas? Thanks as ever, Anthony
There is no limit. Something else must be wrong
with your data file.
or a limitation for how much heap or stack memory can be used
on the machine the job is running on, or an address space
overflow (e.g. on a 32-bit node).
axel
You might hit these kinds of limits with 2.3 billion
atoms, but you shouldn't for 2.3 million.
