[lammps-users] Meam potential
Dear lammps users,
I am a beginner of lammps, I want to konw whether lammps can do close-packed hexagonal lattice(hcp) metals using Meam potentials? If it can do this,how can generate atomic coordinates?
dlh2008
The lattice and create_atoms commands can build an hcp lattice.
If MEAM is parameterized for your material, then it can do an hcp
lattice as well.
2009/7/1 dinglanhua2008 <[email protected]...>:
Hi steeve,
I just got a feeling that the compute stress/atom does not include the KE
part while calculating stress/atom.
From the little knowledge of lammps coding style, it seems KE part of stress
is calculated only for "grouped" atoms and not for all atoms in
compute_stress_atom.cpp.
My doubt rises from comparing the stress-strain behavior of polymer where I
am plotting a component of stress (-pressure) from VIRIAL definition against
sum of {stress_per_atom/volume_per_atom} wth strain.
Both these measures of stress look exactly same except a constant different
through-out the plot.
The figure is attached.
Please let me know further for the reasons of this difference.
Thanks in Advance!!
Kind Regards,
Dhiraj K. Mahajan
http://home.iitk.ac.in/~dhiraj
The doc page is pretty clear about what compute stress/atom
calculates. KE is included unless you turn it off. If you use
a group, instead of all, then it won't be computed for atoms not
in the group.
