Hi all
While running minimization, minimization terminates with stopping
criterion : linesearch alpha is zero, but the total energy of the
system is still very large. So when I try to run NVE, failure occurs
as the atoms just fly away.
How can I overcome this problem and run the minimization for a long
time, so that the system is in a minimia.
Navdeep
Hi all
from where do that atoms fly away?
i would suggest you investigate why.
most likely you have a very unphysical
configuration there and i would try to
resolve that first.
cheers,
Are you running the most current (fully patched) version
of LAMMPS? There have been several upgrades to the
minimizer in the past couple months. I would also try
different minimzer options via the min_modify command.
Also, you can run dynamics initially with fix nve/limit
to get around this problem.
